1978 - 1996 Big Bronco
89' Engine Swap
Old Apr 29, 2006 | 04:50 PM
NotbyChoiceFord's Avatar
NotbyChoiceFord
Unhappy 89' Engine Swap
I own an 89 bronco that has the EFI 300 six, I was wondering if there are any older model V8's that i can bolt up to the tranny. It has a manual tranny, 4 speed with overdrive. I wouldnt mind sticking with a 300, but the largest i want to go is a 351. All i know is that i want to drop a carburated motor in with as little work as possible. Thanks for the help!~
Old Apr 29, 2006 | 04:57 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 29, 2006 | 05:55 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Any small block will bolt right up, thats 260, 289, 302 or 351w
However, those I6es will put out good low end.
Why the swap, is the engine worn out?
Old Apr 29, 2006 | 06:58 PM
NotbyChoiceFord
Im doing the engine swap because i want to get rid of the headache of the EFI want to get back to the carburator!
Old May 1, 2006 | 09:19 AM
Kemicalburns's Avatar
Kemicalburns
well going backwards may cause issues when getting it smogged or licensed. the efi just needs to be understood and it will actually be easier then carbed setup. plus with gas as hi as it is. the efi is superior. tell us whats wrong and im sure we can help
Old May 1, 2006 | 08:58 PM
NotbyChoiceFord
There is nothing wrong, im just a traditional man. where im at i have no problem gettin it to pass inspection because i know a guy. at the moment im running two 8 or 10 inch glass packs and it smokes like a diesel but it still passes, I just really like the carburator!
