91 Ranger Side mirrors
Old Apr 29, 2006 | 11:19 AM
barracuda69ken's Avatar
barracuda69ken
Are the mirrors to a 91 Ranger adjustable? Every time I pass by a semi or get up to 60 m.p.h the mirrior flops back on the drivers side. These are stock mirrors.
Old Apr 29, 2006 | 02:36 PM
Hank85713's Avatar
Hank85713
No I dont think they are, but if it is the whole outer shell you can epoxy the base to help keep it stable. if its the mirror portion they are cheap enough to replace off ebay or even a junk yard. I am getting ready to put elec mirrors on my 94.
Old Apr 30, 2006 | 01:40 AM
RedRangerFeb1990's Avatar
RedRangerFeb1990
I had the same problem.
The mirrors are not adjustable. They didn't use enough material in the rivet type system used to hold the tension spring to keep it from separating/pulling it apart over the years, which makes for a loose mirror. I replaced both of them with brand new ones from the dealer for around 50 bucks each,and they did the same thing again after a few years. I replaced the passenger side with a cheap plastic after market mirror which has a different spring tension design. No more problems. Just to see if this would work, on the drivers side I ground off the rivet type piece that holds the flat tension spring and drilled and tapped it (very small). Then I drilled and tapped the center of the flat spring and put a long set screw in that hole. Then screwed the flat spring back onto the mirror base using the two new holes and small screws. Then I just adjust the mirror with the set screw in the middle of the flat spring. This jams the ball/socket together. It works fairly well but I have to adjust it once in a while. It cost me about 20 cents for the screws and a few bucks for the tap.
Old May 13, 2006 | 07:39 AM
barracuda69ken
RedRanger....Can the mirror be taken off with the two star bolts that hold it onto the door. I hope I don't have to access the inside door panel!
Old May 13, 2006 | 02:03 PM
RedRangerFeb1990
Remove the two mounting torxs screws and the side mirror comes right off.
