Torque for Header bolt on 92 302EFI
Old Apr 28, 2006 | 04:44 PM
Jrock909's Avatar
Jrock909
On a 302EFI motor what is the process you have to torque down the header bolts... Torque them down once and call it good or do it twice once cold and then hot.....
Old Apr 28, 2006 | 05:49 PM
Blurry94's Avatar
Blurry94
Start from the center and work you way out. I've tried several different methods on mine and they always seem to work themselves loose around 6 weeks or so. Then I installed longer bolts with lock washers...problem solved.
Old Apr 28, 2006 | 09:30 PM
Jrock909's Avatar
Jrock909
So install some lock washers....?
Old Apr 29, 2006 | 01:09 AM
Fully_Loaded's Avatar
Fully_Loaded
Locktite and washers. Make sure you snug all bolts first then torque them down. After 500 miles re-check your torque on the bolts. I go by Russian torque specs, goodntite
Old Apr 29, 2006 | 06:45 AM
Blurry94's Avatar
Blurry94
Yes, and possibly some longer bolts. I've haven't had any problems thus far, and I didn't need to go back and re-torque.
