Aftermarket tachometer
Old Apr 27, 2006 | 08:09 PM
Fordman_Evs's Avatar
Fordman_Evs
Hey ya'll,
I've been driving my 1996 F-150XL for about a week now. I want to put an aftermarket tach in to keep a closer eye on my gas mileage. My question is how difficult would it be to install? Or would it be easier to get a different gauge cluster that already has a tach?
Thanks
Evs
Old Apr 27, 2006 | 08:54 PM
tomandbeth's Avatar
tomandbeth
Isn't it amusing that you can get a tach with an automatic but not with a stick? What the heck is up with that?
I've seen aftermarket guages sold to the diesel boys that goes on the driver door pillar. Check to see if that would work for you.
Old Apr 27, 2006 | 09:04 PM
handyman43358's Avatar
handyman43358
It's actually fairly easy to install one.
They normally come with 4 wires, and instructions on where they go. You'll need a source of power. It's better to tap into a circuit that is only on when they key is in the "on" position. One wire will go there. Another wire will be your ground. The next wire will be your input, which will go on the negative side of your coil. The last wire will be for the light inside the gauge (If equipped), which again can be tied into a circuit that is on when your parking lights are on. I tapped into the light on my ash tray for a source of power for all my gauges.
If you have a manual tranny, you might be hard pressed to find a place to run the wires through the firewall. Mine is an automatic, so I cut a slit in the big black boot where the clutch pedal componets would have gone, and ran everything through there.
So basically, you will only have to run one wire through the firewall, which will be the one going to your coil. The others can either be tapped into the fuse box, or any other place inside the cab.
Old Apr 27, 2006 | 09:53 PM
DT98's Avatar
DT98
Smile
I have a '94 2WD 6cyl auto and had room on my dash on the right side to mount a tach. I got a Dakota Digital tach. It's a three digit read out and it looks great but if I had it to do over with again, I would have got a small size old fashioned tach with a needle pointer. I found some that were 2 and 1/8 inch diameter and it would have fit the dash nice. The three digit digital readout changes too fast and a needle pointer on a dial would work better for me. The other posts are right, it's not hard to install, just finding a place to get the pickup wire through the firewall is the hardest part.
Old Apr 27, 2006 | 10:03 PM
Fordman_Evs
Thanks guys. Yeah I know my girlfriend's Dad has a Doddge Dakota with a tach but it's an auto. What about drilling a small hole in the firewall and putting a rubber gomet in for the wire?
Old Apr 27, 2006 | 10:10 PM
handyman43358
Excellent idea. Just make sure nothings is on the other side of the firewall!
Old Apr 27, 2006 | 10:16 PM
12secondstang's Avatar
12secondstang
Changing the cluster is simple and no wiring issues. Just Plug and Play. The trick is finding a 96 cluster at a reasonable price. I put a 95 cluster in my 96. The ABS light came on so I pulled the ABS bulb. I have no ABS right now. Other than that I have a Factory tach without the hassle of mounting and wiring up an aftermarket piece.
A 92-93 Cluster won't work in a 96 but the 94-95 will with the issue stated above.
Old Apr 28, 2006 | 05:04 AM
DT98's Avatar
DT98
Smile
Oops my bad, I should have thought about Dodge Dakota truck...speaking of guages for vehicles and motorcycles, Dakota Digital is a manufacturer of digital guages for all kinds of applications. Somewhat pricey, especially the motorcycle guages but they are nice if you're into digital readouts. They have speedo, tach, temp and pressure guages, etc... Do a google or yahoo on Dakota Digital guages and give a look sometime if you're curious. (I don't work for Dakota Digital or anything like that....) :-)
Old Apr 28, 2006 | 07:29 AM
KW160's Avatar
KW160
I did that exact same thing. Finally found a 96 on Ebay, problem solved.
Old Apr 29, 2006 | 08:00 AM
TexasGuy001's Avatar
TexasGuy001
I have an aftermarket tach mounting on my steering column housing just opposite of the gear shifter. It was an easy install.
southtexasidi
Sep 29, 2015 07:43 PM
RZAR
Aug 11, 2015 09:36 PM
RZAR
Aug 10, 2015 10:58 AM
xaviar
Jun 22, 2014 09:58 PM
coxthecrazy
Feb 1, 2014 10:49 PM
