1966 - 1977 Early Broncos
5.5" lift
Old 04-28-2006, 10:57 AM
earlybroncoboy's Avatar
earlybroncoboy
earlybroncoboy is offline
Smile 5.5" lift
Will the stock driveshafts hadle the angle a 5.5" lift will put on them. I'm deciding to go with a 3.5" and 33's or a 5.5" lift and 35's.I have 4.11 gears and a 302.
What combo do you think Isould run (wich one will work better) thanks!!!
Old 04-29-2006, 12:03 AM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
it can be done but i dont think i would trust the joints at that angle! an EB is just way too short!
as far as gear ratios it all depends on your tranny, t-case, tire size, and intended purpose. however foe arguments sake i will venture out and say those 4.11's would be fine! do you feel you have plenty of low end grunt or do you wish you had more of a highway speed friendly gear?
-cutts-
Old 05-01-2006, 12:21 AM
Boba Fett's Avatar
Boba Fett
Boba Fett is offline
I'd go 5.5 and get new driveshafts with the universals in them. That's what I got and it works just fine.
Old 05-09-2006, 10:20 PM
1bad73bronco's Avatar
1bad73bronco
1bad73bronco is offline
Hey Boba Fett, all driveshafts have universal joints on them, I think your thinking of a CV joint. I have 5.5" lift, it has new driveshafts front and rear with cv's, i believe the shafts have been lenghtened. The front driveshafts angle is pretty bad and i am suprised i havent busted a u joint yet, but the rear angle is pretty good
Old 05-10-2006, 11:39 PM
Boba Fett's Avatar
Boba Fett
THX Yeah, I can't keep track of what those things are called, CV is correct, I just hope I can remember it!
My angles look pretty good. My rear shaft went up a couple years ago.
Old 05-13-2006, 11:49 AM
RCrawler's Avatar
RCrawler
RCrawler is offline
Stock type (with CV joints) extended drivelines will work just fine with 5.5" lift. You will probably need to install tapered blocks or wedges on the rear springs to tilt the rearend to minimize the angle in the rear. With 7 deg caster bushings in the front, the angles should be fine.
Jason
