AAAA... another frame swap post!!
At the risk of you all deciding to unite and lynch me... I'm going to ask anyway! has anyone tried to stick a 54 F100 cab on a 79 ford step side chassis? (keeping the 79 bed) I've searched the forums for two hours trying to avoid the embarassment of asking and found plenty on exlporer and s10 swaps but nothing on a 53-56 to a 72-79. Probably with good reason.Found one guy who stuck his on a Crown Vic. WOW! Anyway, I've stared at my 54 for over a year now wishing I had a truck to drive and broke down tonight and bought a running, drivable 79 for $700.00. Reason I'm wondering at all is 1) I like the 54 cab and front end better 2) my eleven year old helped me get my 54 and he may be heart broken if I totally get rid of it. all that said... let me have it! I think I can already tell the response! lol! At least I'm not contemplating putting a Nissan engine in for better gas mileage!
Most of us agree that it is doable. The guy with the right skills and the right sized wallet will do it with more ease than the guy who has limited skills and a small budget. An FTE'er with some foresight will document each step along the way, much as our fine moderator, George, has done with Earl.
I know a backyard builder in Odessa who could pull this swap off. I don't think he'd want to though, given the time and money commitment such a project demands and what you end up with when completed. The $700 bucks you spent could have almost rebuilt your stock '54 frontend. If you only have a cab and fenders for your project then I'd say you have no choice. No decent truck guy would break an eleven year old's heart.
Have the lad help you and who knows? He might be able to drive it to the prom!
Good luck, himmelberg
Vern
The wheelbase as you know was 110" stock on the 54 so you may have to adjust the frame length to get the front wheels where you want them in the wheel wells. If your thinking of slammin the truck to the ground, you will have issues with the track width and tire clearance, some of which could be corrected with positive offset rims and dropped beams.
I did the frame swap with my 55 (a 69 frame with 74 I-beams) and am happy with the results so far. My desires were for stock apearance and ride height when finished.
Good luck which ever way you decide!
The reality is the "old body on new frame" ends up being MORE work, and in many cases, looks funny when you're finished because the wheels look out of place. (Huntsman's truck is an exception and looks good in my opinion, but his work is exceptional too! Most of the results I've seen weren't near as good.)
If you look at how many folks either a)Rebuild to stock, or b)Go with a new front clip only, it's pretty good evidence that these are the best routes to take, based on time, money, and complexity.
I'd consider taking the engine/tranny only out of that new chassis and rebuilding the stock suspension on your truck. Or, for more of a challenge and expense, take a new front clip from one of the typical F-100 sized donors and then add the new engine/tranny.
Once that is done the challenge will be Z'ing the front frame horns to fit my core support. This frame seemed like a natural good choice and Im not sorry I started it at all. I have a 73 front crossmember to put under it for the disc brakes, dropped spindles and springs are easy to find and it extends my wheelbase by 6". I will cut out the front wheel openings and move the forward 6" like the FR100. It runs a 500 Cadillac and TH400.
Now, I have a 71 F100 frame sitting out behind my shop that is/was a parts truck, that I will measure tomorrow and report back here. Seems to me I took some measurments once and didnt like the idea. As for me I would'nt want it under my 55 simply because the twin I beam is more trouble then the coil spring suspension I get with the Chevy frame.
When I'm done the truck is going to sit at stock height.
