2006 Cam Sensor O-Ring Leak
Old Apr 27, 2006 | 10:40 PM
parcours's Avatar
parcours
Lightbulb 2006 Cam Sensor O-Ring Leak
Just got my truck back from Ford. 6600 miles and this is the second oil leak. This time they found the cam sensor o-ring, first time, rear main.
They had to drain the coolant, remove the fan and fan shroud, remove the AC compressor, etc. to get to the sensor.
Also had the emissions recall done..
I could just imagine how much this would cost if I had to pay for it. I'm seriously thinking of getting a V10... In the long term, a PSD will cost quite a bit more in shop work.
Old Apr 27, 2006 | 11:51 PM
fordman 460's Avatar
fordman 460
Had cam sensor seal replaced and the crank sensor replaced several times. If you are using your truck for towing, I believe you will be big disappointed with the V10 for pulling power not to mention the wonderful 10 mpg most of the time.
