1966 - 1977 Early Broncos
351w swap part list
Old Apr 27, 2006 | 02:59 PM
JCastellaw's Avatar
JCastellaw
351w swap part list
I just bought a 351w HO with a 4-barrell carb. It came out of a 85 Bronco and I am going to install it in my 1974 Bronco which has a 4in lift. The 351w has everything on it including alt and air condition.
My question is What parts do I need to put it in my 74 bronco.
Can I keep the alt, waterpump etc.. or use the one on the 302.
Can you please give me a parts list so I can have everything when I take it to the mechanic!!!
Thanks guys!
Old Apr 27, 2006 | 03:24 PM
JCastellaw's Avatar
JCastellaw
Also will my 302 headers work
What about hood clearance?
Can I use the Oil Pan that is on My 302?
Old Apr 27, 2006 | 08:50 PM
smallblock351w's Avatar
smallblock351w
the headers should work, the oil pan will not as the crank mains are bigger so they made the ends of the block where the pan seals bigger making the 302 pan to small. i believe the 70s ford trucks use a different style power stearing pump then is used in 85 as well. the alternator should be the same. Trying to rember it all i personaly have a 1980 ford f150 but my dad has a 75 f 350. i believe they used a different style ac compressor on the 85 comapred to the 74 as well.
Old May 9, 2006 | 10:24 AM
spartamouse1's Avatar
spartamouse1
you can buy the adaptors so all the factory brackets will adapt to the 351w. that will keep the front end all original. the throtle rod going to the carb has to be lengthened. i had to notch the bracket to the brake booster to clear the valve cover. i used 302 headers but they were very tight to the frame and brake lines but they worked. original drop air cleaner fit also under the hood.
Old Jul 17, 2006 | 04:36 AM
dk5122's Avatar
dk5122
Any further info? Have you started the swap?
Old Jul 26, 2006 | 12:44 PM
JCastellaw's Avatar
JCastellaw
I just had the engine bored and heads rebuilt. getting ready for parts and need a parts list!
