E4od Yuk!!!
Old Apr 27, 2006 | 10:39 AM
Fordsucksagain's Avatar
Fordsucksagain
E4od Yuk!!!
Can any one tell me If I can replace my E4)D with an easyer to find transmission, C4 , C6 or something, with out looseing my feul injection ?
Old Apr 27, 2006 | 10:41 AM
s8whiskey's Avatar
s8whiskey
What engine? If you got yourself a nice 351W you can slap a C6 in there and just have your check engine light on all the time.
Old Apr 27, 2006 | 11:31 AM
andym's Avatar
andym
Short answer - yes you can. I'm not sure if the check engine light would be on or not, though. If you really want to do it right, all you need is a new computer from a junkyard or ebay that was meant to run your engine without controlling the tranny.
Old Apr 27, 2006 | 11:48 AM
Fordsucksagain
As a matter of fact I just rebuilt the 351W and then the transmission craps out on me! Will the C6 be a direct fit? Will I have to change my transfer case as well? and where will I get a vacume line for the Modulater valve?
Old Apr 27, 2006 | 11:52 AM
andym's Avatar
andym
A C6 from a 300, 302, or 351 will be a direct fit. Don't get one from a 460 or a diesel, it won't work.
Your transfer case will be fine. Vacuum lines can be bought anywhere. Since the C6 is shorter than the E4OD, you'll have to shorten/lengthen driveshafts and get a C6 crossmember for your truck as well.
Old Apr 27, 2006 | 12:24 PM
pfogle's Avatar
pfogle
Why not rebuild the E4OD? Make sure they use the updated parts and it should hold up to whatever you throw at it. Any GOOD transmission shop should be able to rebuild it for a lot less than swapping in a new trans.
Old Apr 27, 2006 | 01:43 PM
Fordsucksagain
All the local shops want $2000.00 to rebuild, And thats the cheaper ones, I can get a remanufactured one for $2200.00.
I am a poor sonofagun, raising three teen agers, I cant aford a new truck or a nother transmission, want to buy it??
Old Apr 27, 2006 | 02:41 PM
s8whiskey's Avatar
s8whiskey
rebuild it yourself? I did mine. Im only 18 and a computer nerd
Old Apr 27, 2006 | 03:06 PM
pfogle's Avatar
pfogle
S8whiskey has a good suggestion. You should be able to find a kit for less than $500, it may not include the electronics though.
Old Apr 27, 2006 | 03:41 PM
andym's Avatar
andym
I believe there are several tools that you need to rebuild an E4OD. It's a job that I'm not sure I'd want to tackle - what if you got it back together and it didn't work? Or failed in 5000 miles? I'd be..... well, I'd be upset.
s8whiskey, you rebuilt an E4OD?
