Front axle conversion questions
Old Jul 26, 2002 | 10:06 PM
ecooper's Avatar
ecooper
I am in the process of fixing up a '69 hybrid pickup truck. It's a 4-wheel drive, Dana 60 in back and 44 up front with coil springs. It has a '72 body and a balanced 460 from a thunderbird. I am looking for a cheap Dana 60 for the front and will do the conversion to leafs as well. What I'm wondering is: I've found a wrecked '77 F250 with leafs in the front (dana 44 also) and I would like to get started on the hardware swap(the frame mounts and the shackles). Is all the mounts the same for the dana 60 and the dana 44? In other words: If I mount or weld the shackles and spring mounts from the '77 (F250) on my '69, will the dana 60 bolt up when, or if, I find it? Are the leaf spring mounts the same? Any insight would be helpful
Old Jul 26, 2002 | 11:59 PM
comertrucks's Avatar
comertrucks
As far as I know the spring perches on the dana 44 and the 60 are the same width apart. Hope this helps a little.
Old Jul 27, 2002 | 08:46 PM
Jimbare's Avatar
Jimbare
all alone in the world
perch width should be the same. spring leaf width, and axel housing diameter will probably be different. any good spring shop can make you new u bolt what ever size you want.
Old Jul 27, 2002 | 08:50 PM
Jimbare's Avatar
Jimbare
KoltonFuller
Apr 1, 2014 07:47 AM
69FF100
Jan 24, 2014 02:06 PM
fishindave11
1978 - 1996 Big Bronco
Jun 15, 2012 04:21 AM
dino360
Oct 30, 2004 09:51 PM
fordbronco84
Jan 26, 2004 09:16 PM
