leakkkkkkkk
Old Apr 26, 2006 | 10:48 PM
bohiaa's Avatar
bohiaa
Cool leakkkkkkkk
After replacing all the seals in my 93 F150
I pulled vacume it was kind of hard to tell because of my hoses but I took a chance and filled my system with 134a "I did the conversion."
sure enould it all leaked out with in an hour or so...
I have been searching for this leak all day. I even put in some die and used the black light...
cant seem to find it...
After noticing the ac switch was cracked I replaced and pulled vac again.
"with a NEW set of gauges, and hoses.
It would hold vac for a couple of hours and solwly seek down...NOT a lot
"forget my numbers"
BUT I cant find a leak anywhere.... SO I recharged the system and looked for leaks again and havent found any YET It was dark outside and the black lght should have found it......
If this system is dry in the morning I'm going to just have to pay some one to find it for me I guess......
Old Apr 26, 2006 | 11:25 PM
amish77's Avatar
amish77
well if you checked everywhere else then the only place I can think of is the condensor in the dash.
pinhole leak in it might do the trick.
Old Apr 27, 2006 | 03:21 AM
cheez67's Avatar
cheez67
sometimes aslow leak will not show using the light as not enough oil escaped to be seen. the dye mixes with the oil not the freon. could it be the compressor seal, maybe the dye is trapped behind the pulley and can not be seen yet. did you try spaying the fittings with soapy water while watching for bubbles? it is low tech but it works.
Old Apr 27, 2006 | 10:23 AM
bohiaa's Avatar
bohiaa
thx...
Yea a buddy of mine "that works in an auto shop had told me about that trick.
I'm going to check it today
Old Apr 28, 2006 | 09:54 PM
lsrx101's Avatar
lsrx101
An evaporator leak "is" a possibility, but it's uncommon in those trucks. I would highly suspect the compressor shaft seal on a truck this old. I do a quite a few of them every summer. Actually, I'd be surprised if it didn't leak some. Also, they often don't leak much, if at all under a vacuum. They leak under pressure. The seal is replacable and you should be able to rent the tools to do the job. There's a remover, replacer, and a seal protector.
If the system was ever discharged for more than a year or so it might be better to go with a reman compressor due to pitting on the shaft.
Also, the dye needs to circulate. The system needs to run for a while (at close to full pressure) before it will show up leaks.
Old May 4, 2006 | 12:13 AM
bohiaa's Avatar
bohiaa
Dang I feel like a fool.......
It was the ac switch... It was screwed in too tight and cracked the plastic housing......
I did the low tech thing.....
Thanks Everyone.....
Old May 4, 2006 | 12:16 AM
lsrx101's Avatar
lsrx101
Glad ya found the problem dude!!
Old May 4, 2006 | 10:47 PM
amish77's Avatar
amish77
sounds like a cheap fix. At least you don't have to pay much for being on the wrong track.
apeman426
Oct 11, 2012 12:46 PM
akamacgyver
Sep 20, 2012 04:40 PM
mmjax25
1997 - 2003 F150
Apr 21, 2008 07:17 AM
rcruzer
Sep 12, 2002 12:08 AM
