radiator leak????
Old Apr 26, 2006 | 10:45 PM
62Cole's Avatar
62Cole
radiator leak????
hey.... i was walking top my truck after leaving it in the parking lot for about 4 hours and i noticed a small puddle of radiator fluid sittin on the asphalt below my truck...i watched a few drops fall..checked the radiator fluid level...looked a little lower than it was the day before but nothing significant.... and left for home in a hurry. after i got home it dripped a few more times andf then stopped...and hasn't dripped since...this was 4 days ago...it isn't overflow because it was fine before this dripping incident and i haven't add any fluid lately....is this something i should be worried about????or did i just loose a little fluid Thanks for reading, 62Cole
Old Apr 26, 2006 | 10:55 PM
Kongslibakken's Avatar
Kongslibakken
Have you checked all of the minor culperts loose hoses leaking radiator, loose rad cap bad hoses. You can also check and make sure your water pump isnt ready to go sometimes you can get ahold of your fan and if it moves not in its natural way it may be a water pump. What motor do you have?
Old Apr 26, 2006 | 10:57 PM
62Cole's Avatar
62Cole
i checked the hoses but not the water pump. its a 223 I6
Old Apr 27, 2006 | 02:37 AM
66beater's Avatar
66beater
check the weep hole on the water pump. thats just what they do: leak a little before the pump goes completely. sort of an early warning that the inner seals have died
Old Apr 27, 2006 | 05:27 AM
jowilker's Avatar
jowilker
Cole, The old systems didn't have expantion systems and can not be filled all the way up. You can spend the money for one or the time and make one, but they are not necessary. You need to leave the fluid level down about 2" from the top for expantion and it will be happy.
John
Old Apr 27, 2006 | 04:18 PM
62Cole's Avatar
62Cole
thanks for the help...is there any way to check the water pump without pulling it off of the motor????62Cole
Old Apr 28, 2006 | 09:28 AM
garbz2's Avatar
garbz2
As John states if the level of the water is above the 2" line it will puke it out.
Install a later collant recovery tank and the correct rad cap to allow expansion.
Later units puke it into the can then siphon it back in as it cools.
The water pump if defective in the seal will leak all the time when under pressure. Look at the hole if leaking through the weep coolant will be noticable there along with a stain.
Garbz
happscrap
Nov 19, 2014 09:19 PM
For-dragon
Jun 19, 2014 07:47 PM
Kowboy Kenny
Aug 5, 2009 10:05 PM
62Cole
Jul 29, 2006 02:43 AM
jniolon
Apr 16, 2005 07:37 AM
