Header bolts...
Old Apr 26, 2006 | 09:44 PM
Jrock909's Avatar
Jrock909
Header bolts...
Is it a myth that you have to tighten headers bolts every so often because they work themselves loose?
Thanks for the all replies,
Jason
Old Apr 26, 2006 | 10:03 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
It depends, if you use a fiber base gasket with anti-seize (a must) the gasket will compress hence loose bolts besides they back out. If you go to dead soft copper or copper gaskets with embossed port sealing area, go thru a couple heat cycles then retorque and forget for years. At 34 years over 900K miles this is what works with me and headers.
.....=o&o>.....
Old Apr 26, 2006 | 11:23 PM
Jrock909's Avatar
Jrock909
Awesome, so I definitely need to go with some copper gaskets... I was at AutoZone today and saw some gaskets that were pretty thick and were like $40 they weren't copper but very beefy for header gaskets might give them a try and I also saw some stage 8 header bolts that are suppose to come with fasteners that lock in the bolts that way they don't back out any here is a link to those stage 8 bolts. You have probably seen these before I can imagine....
http://cgi.ebay.com/ebaymotors/STAGE...spagenameZWDVW
Old Apr 26, 2006 | 11:28 PM
j&bsuv's Avatar
j&bsuv
crank em get it hot crank em again
Jeff
Old Apr 27, 2006 | 07:27 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
.....=o&o>.....
i agree, i havent had to tighten one of my header bolts in over 3 years since i went with the good gaskets
SkySkiJason
Dec 13, 2012 01:35 PM
Jrock909
Exhaust Systems
Jun 21, 2006 09:46 AM
onioncasserole
Feb 3, 2005 09:08 PM
jason86
1978 - 1996 Big Bronco
Jan 24, 2002 08:32 PM
fishmanndotcom
Nov 8, 2001 08:11 PM
