flooded
Old Apr 26, 2006 | 06:33 PM
hatchetman2268's Avatar
hatchetman2268
Red face flooded
have an 82 f-150 with 7200vv carb. the venturi diaphram had a tear in it causing it to run badly.I rebuilt the carb but apparently got the float setting wrong. I pulled the carb back off to reset the float but I have a puddle of gas in the intake,need to know how to remedy this situation. I was thinking maybe pull the spark plugs and turn the engine over to let it push out.I figure on new plugs,oil and filter.Any advise will be greatly appreciated.Thanks.
Old Apr 26, 2006 | 07:18 PM
LxMan1's Avatar
LxMan1
Just soak it up with a couple of paper towels. The crank it over a couple of times with the coil unhooked then reinstall the carb. It should be fine.
Old Apr 26, 2006 | 08:39 PM
hatchetman2268
thanks
thanks alot I'll do that.Another question,how would I go about testing the float to see if it might be bad? It's the rubber type.
Old Apr 30, 2006 | 02:26 PM
LxMan1's Avatar
LxMan1
It should float. That's about it. You can put it in a container of water to make sure that it floats.
Old May 1, 2006 | 08:12 PM
hatchetman2268
thanks. I already put it in a container of gas and it was ok.I finally got a hold of a dial indicator to go over my bench settings,put it on and I'm happy to say I'm on the road again.Thanks for all the help.
sixshootingexp
Dec 2, 2012 10:30 AM
danlee
Mar 18, 2010 10:15 PM
hoxiii
Sep 8, 2006 03:56 PM
f100gregus
Aug 13, 2006 11:57 AM
51f1
Oct 3, 2004 10:43 AM
