Pablo, it should be left-hand threaded, but if it's original, you may have to cut it off with a torch. We tried every method we knew, and in the end it had to be cut off.
At the risk of losing my credibility, there is one last resort solution before using the torch. You can drill a 5/16 inch or so, size hole in the fan pulley then stick a metal pry bar or similar in the hole the keep the pulley from turning. Its crude, but effective. You will likely have to file down the distortion that will occur around the hole from the pry lever.
And 1 more quation about pulleys. My friend has aero with original fan (I have electric) and he wants to replace belts, but we tried to remove thes ####ing fan and we have no result. I tried to unscrew it with extreme force, but unsuccesfully! How to do it?
Pavel.....
Pablo my friend, what year and what engine size. My '93 3.0L has left hand thread, and my '95 4.0L has right hand thread. It should say so clearly on top of the fan shroud.
I guess I should have said that I had removed the waterpump/fan clutch assembly after all of my attempts at removal failed. Even with the thing in a vise, we couldn't turn it, and this was at the dealership, with all of their "experts" giving it a shot...lol
His engine is assemblied of 2, as I remember engine from Tauras, but where he've got a fan, I don't know. OK, how to learn what a thread is used LH ore RH? Where is a sighn?
What to do if the shroud is not original?
If it's an engine from the Taurus, it is most likely a 3.0L since the 3.8L is an entirely different beast and probably would have been difficult to put in. In that case, I'd say it has left handed thread.
Don't hold me to this for I might be very wrong, but I think you may be able to tell by the way the waterpump turns while the engine is running. When the pulley turns clockwise (looking at it from front to rear), you have left hand thread so the friction from the fan clutch would tend to tighten it into the water pump. If the pulley turns counter-clockwise, you have right hand thread for the same reason. At least that's the difference I see between my 93 3.0L and 95 4.0L.
It seems to me, we tried to loosen it in wrong direction with so enthusiasm and fanatism, that it is titen so well with so extremal torq. that I don't know how to loosen it! When I tried to rotate it by wrench, crankshaft turns too! I tried to put the screw driver to bellhousing to prevent it, and pulley skids! What to do?
Try holding the pulley with a really good and big pipe wrench. Yes, I can relate to the enthusiasm and fanaticism
mine is marked on the fan shroud which way it turns.
ken
Hi Ken:
So is mine However, Pablo's van doesn't even have the original engine or fan shroud. I think he said they cannibalized a couple of engines to make what he has in there now. In a hospital setting, it's like doing a vasectomy on a patient that might or might not be a male
Hi Pablo:
Wrap the belt around the pulley and put a BIG pipe wrench on the belt. You might have to double up the belt to make sure you don't damage the pulley. But then you would probably ruin the belt. What has always worked for me is to leave the belt on the pulley as is, put a heavy wrench on the fan clutch nut, then strike it hard with a hammer. That's about as close to an impact wrench as you can get
Hello Copper & AeroCo,
At how many miles do we expect to change those bearings?
TIA,
Fordboy49
I only change them when I hear noises or when they seem rather sloppy.
Originally Posted by Pablo-UA
Cooper! I tried to use Hummer! Still no result!
Bummer! I am running out of suggestions. Anything else guys?
Anyway, did you try removing the fan blades first to get some room for a BIG pipe wrench? Other than the pipe wrench, I see no other way if it's that stubborn. The nuclear option would involve making a heavy steel plate to fit on 2 of the 4 bolts on the pulley and weld a big breaker bar in there to keep it from turning. But I never tried that before since I have no welding equipment. If it really comes to that, I think it'll be easier and cheaper to just remove the waterpump along with it and put in a new waterpump and a new fan clutch.
