New Toy!
Once you learn how to run with a 4-Jaw you never look back.
I really want the 3-jaw on to start with, just because I don't have to deal with centering objects I intend to turn down for experimental reasons as I become familiar with the machine and it's operation. I have a pile of 1/2" steel dowel scraps that I wanted to play with threading, putting on a smooth finish, and so on.
The saddle is loose. I can't budge it by hand, but if I put a cutting tool in it and put it against the material I'm cutting, I can get it to wobble or tilt. Maybe I'm applying too much pressure with the tool?
I start taps in my drill press also but I just use my hand to twist the drill chuck. My main home drill press does have a very low speed setting but it does not reverse so I don't use the motor to power tap. I have used other drill presses and mills to do that tho. Maybe I will replace the motor sometime with one that will reverse. The one that is on the press can not be reversed with the wires available.
I have another press that does reverse but it is a very light duty model somewhat similar to but much lighter duty than:
http://www.atm-workshop.com/radial-drill.html
The head would have to be indicated in and it does not have nice slow speeds. I do use it for drilling out broken bolts etc with left handed drill bits since it is much better than hand drilling.
.I turned the drill press by hand because the bench drill press doesn't turn slower than 600 RPM, which is way to fast for a 1/2" tap into a thick lathe chuck. The last thing I wanted to do was break the tap in the chuck. I could have used my floor standing, variable speed delta as that goes down to 150 RPM, but I have it set up and jigged for a project and I didn't want to mess with any of that stuff until I finish making that project.
MSC carries a $75 tapping stand which I've been meaning to purchase, which comes with two collets for larger and smaller taps.
A radial drill is a nice thing to have... it's another thing that was on my list for a long time, then I got the floor standing X-drive Delta and used the funds for that. I was looking at a Grizzly also, and if I recall correctly it's reversable?
While looking around the garage floor for steel pins I made before I got the lathe, I found three rotary optical encoders. I see a DRO in my future.
I also discovered something neat about the lathe... there's a lever that engages the lead screw so that the saddle moves side to side for threading. I moved a lever next to it that's been "stuck" and if the lead screw is engaged in the gearbox, it moves the saddle across the width of the bed instead, also in either direction. Made turning the brake rotor I was experimenting with that much easier (Hey, I'm desperate for material to play with!). The rotor is now nice and smooth, even though it's never going to see time on a car since it's been cut twice before I started playing with it. Was just experimenting with settings, levers, tooling, and so on.
Next I have to learn how to sharpen the carbide blocks. I unfortunately overheated a few of them and dulled them. I've been using the triangular carbide tips in a different cutter holder which is adjustable, thus really useful. My cousin's coming this weekend and going to help me out a bit... he spent 5 years running a lathe for a small shop until he got his accounting degree. Maybe I'll have enough time to weld together the coolant tank so I don't burn anymore cutters or cover myself and my garage with chips. Cutting the backplate flung chips everywhere!
I *really* like this machine a lot. I thought the saddle was loose and warn out, but there are six allen bolts that adjust these "feet" for lack of a better term that makes things tighter, so the saddle doesn't wobble anymore.
Thanks for your help and comments Torque... I'm really enjoying this machine... at this point I could turn things just for the fun of it
Another tip you will not see often is to set the compound at 29° when threading so the chip load is only on one side of the cutter. This helps avoid breakage and erosion at the tip. Also remember that threads have a flat in the root and grind your threading cutter appropriately.
Get yourself a book on lathe operation.
Tooling for a lathe is often more expensive than the lathe itself.
