I'm not sure what it's called but has anyone on here ever used one of those sealants that you use on garage floors? It's like a coating you put down that keeps the cement free of oil and fluid stains and makes cleanup real easy. Anyone ever put something like that down? I have no idea where to start looking but I'm tired of the way my garage is starting to look.
There are a couple different kinds at Home Depot or any other home improvement store. Get the 2 part epoxy and do it right. I'm thinking about doing that to mine, but just a heads up, if you weld or cut on your floor, you WILL burn small holes in it and it doesnt look so nice after a while. Very easy to clean up spills!
I'm buying a new house (new construction, so new concrete in the garage) is it worth doing? I'm thinking that I will never have a better chance to do it than the days before I move in...
Has anyone done this recently and are there any ways to do it for less than the $400 pricetag I am finding online? I haven't been to Lowes or Home Depot yet to check it out, hopefully they have cheaper DIY kits...
Don’t use the cheap stuff at home depot, I did now I regret it, as stated above use the 2 part epoxy, also read the label most of them want a cure time for the concrete, if you cover it before it cures the finish will not last.
You might also be thinking of regular concrete floor sealer. In NY we put it on as soon as you can walk on it. It seals the "pores" in the floor and makes it easier to sweep.
There is some great information on garage floor coatings at Garage Journal. Used to be Garage Junkies, but the name was just changed. Just about any type of flooring option has been covered. Garage Journal
With jacks, and welding, and dragging parts around a coating like epoxy would not hold up on my floor. A bare concrete floor dusts badly tho so I settled on a sealant of some type. I have not settled on a brand tho.
Calling a distributor or dealer for any one of these will get you information. A water base sealer may be better for indoors but a solvent based product seems to hold up better outside. There have been long term tests of some of these products run by various state highway departments.
Thanks, I will call them when I get closer to needing them. A local supplier and manufacturer would be a big plus in my book. They have closed a lot of plants lately tho. Their main location is in Dayton, OH. I have this info for KCK:
DAYTON SUPERIOR
4226 Kansas Avenue
Kansas City, KS 66106
DAYTON SUPERIOR
4226 Kansas Avenue
I was just a few blocks from there yesterday.
That address is the Chemical Division HQ, and Tech Center. The production plant is actually at: 636 S 66th Terrace KC,KS 66111.
Alot of the plant closings aren't really what they look like to outsiders. Many of them have been just consolidations of two or three related companies into a single office. Or in a couple of cases they have moved into a larger facility in a different municipality. There have only been really four 'closings' where they moved out of a market in the last five years or so.
The KCK plant though can't find enough employees. The folks there are working 7 days a week right now.
