Brake Hoses
Old Apr 25, 2006 | 06:38 PM
nktidwel's Avatar
nktidwel
Exclamation Brake Hoses
Hey everyone. I have a '95 F150 XLT. I have not have the truck long. The previous owner said it needed brake work. I found today, that there is a rubber hose not connceted to anything. I know this line is brake related, because when the brake pedal is pressed, fluid comes out. I am not yet exactly sure what the hose is attached to, or what it is supposed to be attached to. Any input, or even a diagram would be appreciated. The Haynes manual is not too helpful.
Old Apr 25, 2006 | 06:41 PM
andym's Avatar
andym
Holy crap. Are you sure?
Can you get a picture of it? Are you sure it's brake fluid coming out and not gear oil? There's a vent tube off the differential that allows for heat expansion.
There should be three hoses - one for each front caliper, and one in the back for both rear wheels.
Brake hoses are cheap and easy to replace, so that's the good news. I would jack it up all around, take all the wheels off, and carefully inspect everything! Brakes are obviously super important, and you could kill yourself if you do something wrong. We'll help you through everything, but keep that fact in mind.
Obviously - don't drive it until you fix it.
And welcome to FTE!
Old Apr 25, 2006 | 06:49 PM
nktidwel's Avatar
nktidwel
Thanks for the prompt reply. I think it is brake related, since fluid only flow while the brake pedal is pressed, also, the brake fluid empties during the day, while I have been working, trying to solve my brakeing problem. I am able to stop, I think the front brakes are the ones functioning. I will see if I can get a camera to take a picture tomorrow. Brake work is only tip of the iceberg, so I will be around alot.
Old Apr 25, 2006 | 06:55 PM
andym's Avatar
andym
YOU'RE DRIVING IT LIKE THAT?????
Please reconsider that. It's foolish and incredibly dangerous.
Old Apr 25, 2006 | 06:56 PM
nktidwel's Avatar
nktidwel
Just today... Not very long at all.
Old Apr 25, 2006 | 11:20 PM
nktidwel's Avatar
nktidwel
somebody said the hose might attach to the axel?
Old Apr 26, 2006 | 11:40 AM
andym's Avatar
andym
On the driver's side of the rear axle, on top, you'll see a small metal block with two steel brake lines and two rubber hoses coming out of it. The steel lines go to each rear wheel, one rubber hose is for the differential vent, and the other is the brake line for both rear wheels.
I hope that answers your question...
Old May 10, 2006 | 02:39 PM
nktidwel's Avatar
nktidwel
Yes that did. Thank you.
