Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Fired up the Merc
Old Apr 25, 2006 | 04:54 PM
Corner Gas's Avatar
Corner Gas
Thumbs up Fired up the Merc
I was over at the farm this weekend getting things ready for seeding. I climbed in the Merc pumped the gas half a dozen times, pulled out the choke and she fired right up. Put on some new mirrors so I can see whats behind me. Some time this week get the drivers side floor ready to weld in a new floor panel and get some new tires for the front and she will be good to go.
Old Apr 25, 2006 | 05:54 PM
preppypyro's Avatar
preppypyro
Sounds good man, bet it felt damn good to start er up!
Old Apr 25, 2006 | 07:41 PM
Fomoko1's Avatar
Fomoko1
My 69n F100 was the same way this spring, it`s a great feeling when the first start up goes that easy.
Old Apr 25, 2006 | 08:16 PM
Dustin1690's Avatar
Dustin1690
yeah thats always a good thing to hear that she started without any trouble
Old Apr 25, 2006 | 10:05 PM
Corner Gas's Avatar
Corner Gas
Ah yes, so nice to have everything fire up the way it is supposed to. I still can't get over how nice that motor runs.
Old Apr 25, 2006 | 11:00 PM
preppypyro's Avatar
preppypyro
What does it have for a motor corner gas?
Old Apr 26, 2006 | 10:25 AM
Snowking's Avatar
Snowking
Is that your only grain truck?
Old Apr 26, 2006 | 10:23 PM
51dueller's Avatar
51dueller
It's probally a 330 FE engine. My cousin has that engine in his '66 M-500 but it takes forever to get up to speed with only a 4spd.
Old Apr 26, 2006 | 11:02 PM
preppypyro's Avatar
preppypyro
Oh yeah, not too ballsy?
Old Apr 27, 2006 | 02:42 PM
Corner Gas's Avatar
Corner Gas
I am not sure of the motor, it's pretty good though, you can load her right up and she pulls it no problem. It has a 2 speed axle and that helps out in the field, but down the road about 45mph is about as fast as you want to go anyways
Old Apr 27, 2006 | 02:45 PM
Corner Gas's Avatar
Corner Gas
Snowking that is not our only truck, our main one is a GMC. I bought the Mercury to use as a service truck but it turned out it was to good for that so I use it as a second truck during seeding and harvest.
Old Apr 27, 2006 | 09:25 PM
preppypyro's Avatar
preppypyro
WHat size motor does the gmc have in it corner? 366, 427..??
Old Apr 28, 2006 | 10:05 AM
Snowking's Avatar
Snowking
Detroit diesel, Our GM tandem is a 82 with a 8.2 litre Detroit. (Sadly the best macine on our farm is made by shiver GM shiver.
Old Apr 28, 2006 | 10:57 AM
Corner Gas's Avatar
Corner Gas
The GM just has a 350 no ***** at all, burns oil and requires a carb kit about every other year even with two fuel filters. It is an 86 only has 40,000kms. It has not been a very good truck. However it does have air conditioning which is nice during harvest.
Old Apr 28, 2006 | 11:07 AM
Snowking's Avatar
Snowking
Our Detroit you have to drive with the windows down and the heat on, she'll boil on you if you don't. We also got a 63 IH loadstar 1800 and a 61 IH B150, both with 345 V8's. The loadstar has been running rough since winter, and we found out the Water pump was ready to go.
You don't know what hell is until you have to replace a water pump in a old stubnose, espically with the Butterfly hood. Each time the wind blows it crashes on you.
