You may have to take the kick panel off remove the vent, and reach around back inside to get it to the hole. You may or may not need to remove the parking brake pedal for clearence. If you have to do this, pull the crap out at the bottom of the vent. Leaves, pine needles, etc.. while you got it apart.
Your right tractoman Moisture and corrosion will mess the fuse block up. mine was gone and I couldn't even tell by looking at it. Now rewiring with a Painless 12 cuircut breaker systme
