A/C leak
Old Apr 24, 2006 | 12:29 PM
bassproguy07's Avatar
bassproguy07
A/C leak
I think i have a leak in my A/C coolant lines but am not sure of how to find it? are there any simple ways of doing this and is fixing a leak cheaper then replacing the hoses? My dad used to work on air conditioners and he said that coolant doesnt just go bad, you have to have a leak. Otherwise i would have replaced the coolant and been done with it. Its gettin real hot here and i need my AC or the truck will just have to sit for a while!
Old Apr 24, 2006 | 05:11 PM
Chevy_Eater's Avatar
Chevy_Eater
You can get a leak detector kit just about anywhere, it's comes with a can of florescent that you charge into your AC system and a black light pen to find your leaks.
Old Apr 24, 2006 | 07:55 PM
bassproguy07
sweet but what if it is a leak somewhere not accesible with a black light???
Old Apr 24, 2006 | 10:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That is very few places.
The evaporator coil inside the heater is the only place you can not see. There are no connections in there.
Old Apr 24, 2006 | 10:24 PM
G'sRed99F150's Avatar
G'sRed99F150
Where there is refrigerant, there is oil. If you don't find it in the engine compartment, when you check the evaporator (inside) or the condensor(in front of the radiator), look for oil, then use the flourecent detector.
Old Apr 24, 2006 | 11:19 PM
bassproguy07
ok ill give that a shot!!! where would u get one of these ac leak tester kits???
Wayne242
Modular V8 (4.6L, 5.4L)
Aug 10, 2013 06:32 AM
EXMAN123
Jul 30, 2010 04:34 PM
Thunder Road
1997 - 2003 F150
16
Jul 19, 2008 09:49 AM
golakers
Sep 24, 2005 05:02 PM
strike
3.0L V6
Jun 25, 2003 04:07 PM
