Fuel Guage shows E
Old Apr 24, 2006 | 08:44 AM
Dirty_Pile's Avatar
Dirty_Pile
Fuel Guage shows E
Here is my story; I run my front tank down to 1/4 then switch to my rear tank, run it down to a 1/4 and then fill both tanks and start the cycle over. Well this time when I switched to my front tank the needle on my fuel guage droped like a rock to the big "E". I know the tank is full, but is shows empty. Any suggestions where to start on this?
Old Apr 24, 2006 | 10:43 AM
1997F-350's Avatar
1997F-350
are you sure someone didnt siphon it from you?
i guess the sending unit is probably bad. someone who knows more about tanks will be along to help i am sure. i would suggest running it empty if you got to pull it.
Old Apr 24, 2006 | 10:55 AM
FARM69's Avatar
FARM69
I though they always pegged out full when they went bad?
Old Apr 24, 2006 | 02:52 PM
Brians97F250Crew's Avatar
Brians97F250Crew
actually if you're gonna take the sender out just yank your bed off. It's a whole lot easier to work on. I just did mine. While in there replace the lower pickup assemblies in both tanks as a preventative.
Old Apr 24, 2006 | 05:46 PM
helifixer's Avatar
helifixer
a wire chaffed to ground would cause the gauge to go to empty, check wiring from sending unit ti switch if only on one tank.
Old Apr 25, 2006 | 10:25 AM
Dirty_Pile's Avatar
Dirty_Pile
I know it was not siphoned. I will check the wiring a little closer. Thanks
