Let us know what happens. I would say if you could mount it in front of the radiator, then it is deffinately worth a shot. Your other option would be going to a two-cooler setup. I have seen this on some 4x4's. However, I don't think I would go that route unless I had absolutely no other options.
Did another towing test run, 210F at 50mph in 3rd one way, 205F at 45mph in second with a head wind the other way.
I gave up on the notion of R&R'ing the A/C. So I'm now running the trans fluid into the radiator cooler, then into the stock A/C condensor. So far so good. 160F max running 65-70 on my test drive. I'll do a towing run this weekend probably.
Just looking at your signature ... 2.75 gears. You're going to get a lot of slippage/heat with that ratio, especially with any kind of towing. The C6 has no lockup.
Did you check your sending unit as Piffery suggested?
21' bayliner classic. A fiberglass, deep-v hull, 130HP inboard/outboard monster. Weighs about 3000lbs on the trailer. Probably about the towing limit for my '77 if I had to guess.
I thought I had confirmed the temperature. I'll be towing again tomorrow. I'll take my IR thermometer and check it again.
Got the second test run in with the A/C unit as a tranny cooler. Towing the 3000lb boat at 60mph, 'cause faster would be stupid with 70's era 1/2 ton brakes, the transmission held 210F reliably. When I slowed down in town it dropped to 180F. The gauge read 180F when I parked and I pulled out the IR thermometer and measured the cooler tube going into the A/C unit to be 172F. I figure that to mean the gauge and IR thermometer agree considering the IR reading is 6' from the transmission and in the airstream. So it's appears I can now tow without overheating the tranny or fluid.
The fluid runs into the stock radiator cooler, then into the A/C condensor. The A/C condensor is in the stock location, except flipped side to side so the ports are on the passendger side for easier plumbing.
