Fuel Testing port
Old Apr 23, 2006 | 05:11 PM
thomadm's Avatar
thomadm
Fuel Testing port
Hey everyone, been awhile since ive posted. Been busy lately. Anyways, tried testing the fuel pressure today and with the engine not running, its a little under 40psi. Took the guage off and now the little port or nipple on the fuel rail leaks gas. Tried agitating the valve but it still leaks. Where can i get one of these things other than the dealer? Im not even sure what its called and ive never seen one in a parts store around here.
Any help will be appreciated.
Old Apr 23, 2006 | 06:56 PM
Franklin2's Avatar
Franklin2
It's called a schrader valve. It's just like the valve in your tires. You can get a little tool, and after you let the pressure off, you can unscrew the valve just like the tire guys do. I do not know if the rubber in the fuel type valve is different from the tire type, but at least you could unscrew it and see if you can find a piece of dirt or something in it.
I found a tool to get the valve out of all places, on the valve stem of a two wheel dolley I bought at lowes.
Old Apr 23, 2006 | 07:35 PM
thomadm's Avatar
thomadm
Thanks franklin, ill try that. I got it to slow down just playing with it but it is still leaking slowly.
happeetxn
21
Nov 14, 2007 02:40 PM
daveman8963
Engine Swaps
Jun 17, 2006 05:40 PM
SnowmanMike
1983 - 2012 Ranger & B-Series
Jun 9, 2006 03:25 PM
johnsonswamp
Offroad & 4x4
36
Mar 28, 2006 04:56 PM
Brians97F250Crew
6.4L Power Stroke Diesel
Feb 8, 2006 03:38 AM
