95 f250 dyno
Old Apr 23, 2006 | 04:02 PM
power stroken's Avatar
power stroken
95 f250 dyno
hello all it's my 1st time posting and I thought id post up what my truck made on the dyno, and hopfully get some ideas on what I should get done.
Well it made 170/320 on stock setting and 200/400 on the performance seting with my super chips tuner. In the next couple of weeks im hoping that its going to get a fmic, 4" exsaust, air intake, maby a bigger turbo. Any other ideas ??
Old Apr 23, 2006 | 04:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Hi. Welcome to Ford Truck Enthusiasts!!
Sounds like normal numbers for a stock rig. Your stock turbo will support a bunch more power than you are currently making, don't be so quick to throw it away.
You didn't mention gauges, you should add a set of gauges (boost, pyro, and trans temp) prior to any significant power upgrades. After that and the mods you listed, you'll need a better flowing set of injectors to really make some power.
Old Apr 23, 2006 | 10:04 PM
1997F-350's Avatar
1997F-350
what cookie said.
i have a stock turbo still with 160cc injectors from bdp (stock is 98cc unless a ca truck which are 130cc) and have no problem.
supposidly these things make a little over 300 rwhp. i have yet to dyno it. soon hopefully now that i am in psd heaven (pac nw).
also get an adjustable 4 or 6 pos chip.
new injectors are a night and day difference.
