Power Steering
Old Aug 13, 2002 | 04:27 PM
jeremyd72's Avatar
jeremyd72
Post Power Steering
Old Aug 16, 2002 | 01:18 AM
showle's Avatar
showle
Power Steering
Hey guys
I have a 70 swb f-100. 2wheel drive with the 302...its all stock but i want power steering...what do i need to do?
thanks
Old Aug 16, 2002 | 01:29 AM
sparky's Avatar
sparky
Power Steering
Find a donor truck with power steering, 67-79. I am not sure but I think it will have to be an F100 maybe an F150. The F250's and F350"s are totally different I think.
Then harvest the parts you need. Like the power steering box, the steering column, pump, lines and brackets. Then install them on your truck in the way they were installed on the donor truck.
sparky
Old Aug 16, 2002 | 09:56 AM
AaronW's Avatar
AaronW
Power Steering
As far as 2wd drive go, I don't think there is a difference. I recently converted my 69 250 to ps from a 72 f100. I didn't have to swap engine perches, some of them you will, depends on the box. Look carefully, it should be easy to tell if you will have to swap perches. Get the column, box, pulleys, and pump off of the donor truck. Throw an inline filter in there too, I didn't do that and I will be buying a new gearbox soon.
AW
