1966 - 1977 Early Broncos
Flex plate to small?
Old Apr 23, 2006 | 08:31 AM
ubdh's Avatar
ubdh
I have a 1967 bronco with a 351W ('79 block with '69 heads), C-4, PS, PB. We just took out my tanny and tranfer case and got them rebuilt. We replaced the flex plate, starter, and bellhousing. The new bell housing we installed was the older style (larger- the right one).
When we put it together and the starter would not engage the flex plate (bendix is working). Bottom line the flex plate we beleive is a 157 teeth and it is just to small it will not reach the gear on the starter.
Is there any quick fixes besides replacing the flex plate? How about a different starter. The existing is 2 hole.
Also some of my rocker arms appear to be hitting the top of the valve spring (cap). Seems like the lifters are short??? Would this be because of the 69 heads?
Bruce
Old Apr 23, 2006 | 09:11 AM
ken75ranger's Avatar
ken75ranger
you need a 164 tooth flexplate. You could go back to the smaller housing. No options without removing the tranny.
The rockers could be 2 things. Did you put in bigger valve springs? Sometimes the rockers hit the springs in the stamped area of the rocker where the trunnion rides. If it's there you'll probably have to go to aftermarket rockers.
To check the pushrod lenght get a Sharpie and mark the tip of the valve. Turn the motor over by hand a few times. The valve should be wiped clean in the center of the tip.
Old Apr 23, 2006 | 05:00 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Bruce to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
