This might be a silly question
Old Jul 8, 2006 | 12:15 PM
mikeyswood's Avatar
mikeyswood
Do I need to repin anything for my 351 if I am using the harness and A9P from a Mustang?
Mike
Old Jul 8, 2006 | 02:56 PM
EPNCSU2006's Avatar
EPNCSU2006
As long as the harness matches the computer, you are good to go. The mustang uses the same firing order as the 351, so nothing needs to be done there. If you are making a harness from a truck harness, you'll need to move a couple pins other than the injectors to match the computer, but if you are using the mustang harness, you shouldn't have to do anything at all.
Old Jul 9, 2006 | 08:40 AM
mikeyswood's Avatar
mikeyswood
Thanks!
If I understand this, I will have to change the distributor connection and lengthen the MAF and throttle body connections.
Mike
Old Jul 10, 2006 | 09:14 AM
Kemicalburns's Avatar
Kemicalburns
www.fordfuelinjection.com should have pictures showing what you ask as well
