Dual tank ?
Old Apr 22, 2006 | 06:57 PM
TwowhL's Avatar
TwowhL
Dual tank ?
My 93' f250 w/ 460 does something strange in the way it pulls fuel from the tanks.
If I start with an empty front tank and a full rear tank, by the time the rear tank is 1/2 empty, the front tank shows 1/4 full (remember it started out empty). it ( the front) indeed does end up with fuel in it as I toggle over to it later to finish off my fuel.
Sounds like there is some bleed over to the front tank from the return line.
Anyone else notice this?
Is there a check valve or other component responsible for this?
Thanks for any input.
Old Apr 22, 2006 | 07:01 PM
ncranchero's Avatar
ncranchero
Check valves in the front tank pump module are bad. Take a few minutes and read all of the fuel tank posts here. Yours is the typical pump/tank problem....... replace front fuel pump.
https://www.ford-trucks.com/forums/s...earchid=519200
Old Apr 22, 2006 | 11:24 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
My son's 1991 F250 with 460 motor had to have both fuel pumps replaced.
The new fuel pumps (and new wiring harness for them) have the check valve installed inside each pump. We replaced one at first, but problem was still present and then after two new pumps.... good to go!!!
There was an old TSB and old NHSTA recall for this issue, but it has expired. I even tried having the govt. re-instate as the front tank would pressureize and spit gas all over my son when he opened it and gas would go on the ground (environmental and safety issue)... but no luck and no reply (typical)!!
Good luck... it is normal.
Old Apr 24, 2006 | 10:27 AM
TwowhL's Avatar
TwowhL
Thanks
Looks a new fuel pump (or two!) is in order.
Old Apr 24, 2006 | 11:16 AM
the_hetz's Avatar
the_hetz
Old Apr 24, 2006 | 07:07 PM
subford's Avatar
subford
No fuel selector for 1993 so it is the pump.
chrismartinez0
Jul 1, 2010 01:25 PM
F250351W
May 13, 2010 02:50 PM
abmitchell
May 23, 2006 03:56 PM
my93
Jan 8, 2005 12:32 AM
zerocash
Jul 27, 2004 08:10 PM
