Brake pedel pulsating
Old Apr 22, 2006 | 01:13 PM
scottmotorsports's Avatar
scottmotorsports
its not consistant but my brake pedal pulsats under braking. Sometime very bad..I have new roters on now and it is still happing..any ideas? I have read about vehecle speed sensor problems
Old Apr 22, 2006 | 02:35 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Who put your rotors on?
Could be warped rotors.... check your owners manual, but my 2003 calls for 150-165 lbs for all lug nuts. If a tourque wrench was not used, and either an impact wrench, hand or those "tourqe sticks" that go on an air gun... maybe to blame???
Warping rotors and "pulsating" have been frequent topics for 2 - 3 years on this site. May take to Midas or dealer and get a "free check" and see what they say without you saying anything... just so you can compare.
Maybe something else, but this is a first place to start.
Let us know.
Old Apr 22, 2006 | 03:52 PM
scottmotorsports
I put the rotors on they are sloted and frozze. They have been fine, but thats what I thought it was, I put brand new rotors on today and as I pulled out of the driveway I had the same pulsating right away.
Old Apr 22, 2006 | 07:31 PM
rcullum's Avatar
rcullum
I had the same problem with a new set of performance friction rotors on my 2000 Excursion. I thought I had did something wrong intially however I found out the rotors were warped from the get go. Carolina clutch replaced them. The moral of the story is sometimes they come that way from the factory. I wish I can say the performance friction rotors solved my problem. They lasted around 40,000 miles before warping.
Old Apr 25, 2006 | 09:20 AM
rlh68050's Avatar
rlh68050
I just did the rotors and pads on my '01 last night. I used all Bendix parts. Took it for a ride around the block and all was good. This morning while at hiway speeds I noticed some pulsation (I was pissed at first). It was raining, and I suspect what was happening was the new pads/rotors were not seated/broke in yet. The more I used the brakes the less the pulsation was. I read right on the Bendix box that it takes ~100 miles for the new pads to "break in". I am going to wait until a dry day before I fault any of the new hardware I installed.
Old Apr 25, 2006 | 02:24 PM
turboale's Avatar
turboale
Its also a good idea to do some heat cycles for these harder pads/slotted rotors when you first get them on. Also try to hold the brake pedal down as little as possible when coming off a long off ramp. Nothing spells warped rotors like an extremely hot caliper clamping down on the disk at one point for an extended period of time.
Old Apr 27, 2006 | 06:01 AM
Downriver Thunder's Avatar
Downriver Thunder
New rotors are not necessarily trued. Some shops will actually take new rotors and true them up on the lathe first.
Old May 1, 2006 | 02:07 PM
cooper's Avatar
cooper
I am having the same issue currently. I just replaced all my tie rods too. The truck was not having any issues until I replaced them too. I noticed that the drivers side inner tie rod was frozed solid as well. I am going to remove the rotors and have them checked and trued.
