Finding axle center line
Old Apr 22, 2006 | 09:18 AM
51dueller's Avatar
51dueller
I'm swapping my '51 F-3 body onto a 78 F-250 supercab frame and I'm having trouble to pin point the front axle center line. It is a little difficult with the beams not perfectly straight and also having the engine removed so the suspension has raised a couple of inches. Does anyone know a sure simple way to find it or know exactly the measurement from the front of the frame to the axle center line?
Old Apr 22, 2006 | 09:37 PM
FordBoypete's Avatar
FordBoypete
Using a square and a plumb bob, or a spirit level, plumb up from center of kingpin. Square off the edge of the frame using your square & mark a line across rail flange. Repeat on other side. Now pull a dryline, or clamp a straight edge across both frame marks & use that as front axle lateral centerline from any point on chassis [frame].
FBp
Old Apr 22, 2006 | 09:47 PM
51dueller's Avatar
51dueller
Thanks very much!
Old Apr 22, 2006 | 09:51 PM
FalconStng's Avatar
FalconStng
You might want to be sure that the F250 front end is in good shape...if the radius arm bushings are bad then the axle may not be exactly where it should be front to back.
Tracy
Old Apr 22, 2006 | 10:32 PM
51dueller's Avatar
51dueller
I thought about that but one side has brand new ones so I guess I have to measure on that one.
