Starter problem, 94 F150
Old Apr 22, 2006 | 05:17 AM
somewherre's Avatar
somewherre
Every so often when I start the truck (94 F150), at the the tail end of the starting when the key is still turned, it briefly makes that kinda high-pitched grinding sound like when you try to start a car that's already running. I don't believe I'm holding the key over too long, and it doesn't happen every time...maybe 1 in 10 or so starts. Any ideas on what's going on or what might need fixing?
Thanks, Michelle
Old Apr 22, 2006 | 07:10 AM
Lazy K's Avatar
Lazy K
Check that the starter mounting bolts are tight. Other than that it sounds as if the over-run clutch on the starter pinion gear is getting tired.
Old Apr 22, 2006 | 03:25 PM
somewherre's Avatar
somewherre
Thanks! Will check the bolts and hope for the best.
ms_michelle
20
Mar 7, 2022 12:09 AM
Michelle Pip
1997 - 2003 F150
Dec 3, 2012 12:21 PM
somewherre
General Automotive Discussion
Apr 23, 2006 12:36 AM
somewherre
Apr 10, 2006 03:36 PM
angelpig
New Member Introductions
Jun 1, 2005 07:30 PM
