D44 - D60
Old Apr 21, 2006 | 08:35 PM
oldfords4ever's Avatar
oldfords4ever
D44 - D60
what is the best way to tell the differents about a D44 and a D60 fronts. What should I look for?
Old Apr 22, 2006 | 08:49 AM
teds74ford's Avatar
teds74ford
First, the 60 is physically larger, and has a "60" cast in the bottom right web by the diff cover.
Old Apr 23, 2006 | 03:31 AM
ivanribic's Avatar
ivanribic
Is there a particular year you're looking at? 78-91 D60 axles use kingpins whereas the D44's used a balljoint. Look at the top of the knuckle. D44's will be ball joint, having 1 giant nut on the top of the knuckle. D60's (from 78-91) will have a cap on the knuckle with 4 bolts in a rectangular pattern that hold the cap on. If you see the 4 bolts on each side it's a D60. Of course later model D60's went to ball joints so don't get them mixed up.
Old Apr 24, 2006 | 07:41 AM
oldfords4ever
I am looking at a 1972 F250. Would a '72 F250 have a 60 or would it most likely be a 44?
Old Apr 25, 2006 | 06:58 AM
teds74ford's Avatar
teds74ford
Probably a closed knuckle, drum brake dana 44. Then again, you might get lucky, and they swapped in a $5000 dynatrac 60 I wouldn't hold my breath, though.
Old Apr 25, 2006 | 07:27 AM
oldfords4ever
Thanks for you help guy. I was thinking the axle was going to be a D44, because I pulled a D44 front out of a 79 F250 a couple months ago.
somethingclever
Mar 18, 2016 08:24 AM
abosely
Nov 23, 2015 06:04 AM
JB78f150
18
May 30, 2012 11:35 PM
BACRAKR
May 3, 2009 02:59 PM
Galaxie427
May 11, 2004 07:21 PM
