Jetting Question
Old Apr 21, 2006 | 12:35 PM
tractoman's Avatar
tractoman
Jetting Question
I had to drop the primary jet sizes to a .095 and use 70/57 metering rods on a 625 cfm Carter AFB on my '76 F250 w/460 and C6 to pass California smog. The primary and secondary jets are now the same size at .095. Is this OK or should I put smaller secondaries in? My performance is a little less than when I had the .100 primaries in there but seeing the CO level on the smog machine, I can't handle that much unburned fuel at $3.00 a gallon. Thanks for the help.
Mike
Old Apr 21, 2006 | 01:55 PM
amish77's Avatar
amish77
If you are seeing unburned fuel with the .100's then the .095's should be fine. I'm guessing you won't lean it out to the engine damage level with that little change, especially if it was rich with the old jets.
Old Apr 21, 2006 | 03:36 PM
tractoman's Avatar
tractoman
What about leaving the primary and secondary jet sizes the same? Is it OK?
Old Apr 22, 2006 | 12:32 PM
amish77's Avatar
amish77
yeah, the point of secondaries to to make power. If you hit it, you want all the power you can get. So the secondaries generally dump more fuel than the primaries, which have a smaller jetting to improve fuel economy. This is why a lot of guys can get better economy with a 4 barell then a two barell. It sounds like in your case that the secondaries are throwing more gas then the engine can burn. As long as the secondaries can keep up with the engine you're fine. You saying that there was unburned gas in the .100's means that going a little leaner with .095's isn't gonna hurt anything.
