vacuum wiper motor
Old Apr 21, 2006 | 10:56 AM
46yblock's Avatar
46yblock
vacuum wiper motor
I've been messing around with my motors to see if they can be made to work. There are three on the shelf. The two that I've had apart both had the leather seal which looks like it fits into the beveled protrusion coming down from the top plate, worn badly. I cleaned the better one up and added a small amount of fresh grease, but it doesnt seem to work. It has a vacuum leak. Does anyone have a schematic of the parts of the motor and airflow diagram, or any other suggestions?
Old May 2, 2006 | 07:25 PM
5 Star's Avatar
5 Star
Vacum Wiper Motor
Try some vegatible oil, make sure all parts are clean then reassemble. You may have to work it a little, and it might come back, if not try another leather and do the same.
Another tip that works, ever go up a small grade and find when you step on the gas your wipers either stop or slow down a lot.
Take that useless factory oil filter, and put it to good use. Block off all the oil supply to the filter, and to the oil pan, then hook it up to the vacum side for a reserve, works good and that now useless oil filter becomes a new usefull accessory.
Old May 9, 2006 | 09:29 AM
Elder Rodder's Avatar
Elder Rodder
I've got a '46 sedan assembly that I ran for awhile and then replaced with an electric unit. Works fine and is complete. It even has the dash control **** and cable.
Elder Rodder
Old May 9, 2006 | 09:39 AM
46yblock's Avatar
46yblock
vacuum wiper
Elder, I will send PM.
Mike
Jolly Roger Joe
65
Jan 22, 2017 06:30 PM
dnkensinger
Aug 27, 2016 07:06 AM
larrycaruso
Sep 20, 2015 09:22 PM
Spitfire372
Nov 14, 2013 04:24 PM
moe
Jun 15, 1999 09:07 AM
