30,000 mile service cost
What should a 30,000 mile service cost. Last time I was at the service department, they gave me a price list that has a bunch of crap (Krex additives, cleaners, etc...) that they are pushing. Not to mention, the 30K mile service was listed at $440.
The service rep tried to tell me to do it because it shows Ford that you take care of the truck and they'll be more cooperative with warranty repairs. I didn't get into it at the time but I need the service now. I'm sure I'll hear the BS sales pitch again. Do I just tell them to do what's in the maintenance schedule and what should it cost?
Thanks
Thanks
I did the 30,000 myself and costed me less than 50.00. I figure unless there's a job that requires tools I don't have or can't borrow, or if it's just too hitech for me, I'm going to keep doing it myself. I just don't trust stealership's to be honest and to do the job right. Almost everytime I 've tried taking my vehicle for an oil change they do something to tick me off. Leave the dipstick partially out, leave spilled oil all over the area of the oil filter, etc...
Originally Posted by kkester
When I had my 2005 Expedition in for the 15,000 mile service, I assumed that I would get those items specified in the manual. Instead, there were a number of add-ons ("dealer-recommended") and a labor cost of $175. Total cost for this visit: $327.
Thanks
Originally Posted by ford390gashog
when i did my 30k it cost me 34.00. that includes 12 quarts of mercon v and oil and filter change.I also had 3 extra quarts of mercon laying around so i did a powersteering flush .
$68 + $9 + $3 = $90.
Am I getting my Mercon V from the wrong places?
I checked a few places and its about $80 for a tranny flush and an oil change you can get for $20 lots of places. For $10, I dont want to bother.
Am I missing something? I am about to tow my 5500 lb trailer 2000 miles, so I need to get the tranny done before I go.
30K Mile service questions
My 2003 Expy is due for its 30K mile service as well. I called the local Ford dealership and got an initial quote of $455.
I then asked the Service Dept Rep to break the quote down into each service item, which he did (sort of). In the conversation he indicated that their 30K mile service included a coolant flush, which made up $90 of the entire bill. However, this work is not even recommended for the 30K mile service on the Ford website. The website recommends the replacement of GREEN coolant at 45K, 75K and 105K miles. And since I have the GOLD coolant, which is good for 100K, there is no need to have it changed for quite some time. So we are down to $365.
Then he mentioned that if my Expy has "the automatic transmission reservoir that has a dipstick" then the tranny fluid does not need to be changed until 100K miles. Is this true? I'm skeptical. In any event that was another $160 saved. So for my $205 I would get the following:
Thoughts on the cost of what I'm getting, as well as the normal life expectancy of the transmission fluid, dipstick or no dipstick.
Thanks in advance!
- Inspect and lubricate steering linkage, ball joints, suspension and, if equipped, half shafts drive shaft and u-joints
- Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
- Inspect complete exhaust system and heat shields
- Inspect engine cooling system and hoses
- Inspect wheel ends for end play and noise
- Perform multi-point inspection
- Replace engine oil and replace oil filter
- Replace engine air filter
- Replace fuel filter
- Rotate and balance tires
Thanks in advance!
Replace fuel filter
I get all of this at my local Precision Tune for about $40, doesn't pay for me to waste my time or get dirty and they let me watch if I want to
Replace fuel filter
Here's what the dealer wanted for a 15,000 mile service:
Change oil and filter
Lubricate chassis and suspension
Rotate tires
Check tire pressure
Replace air filter
Inspect ball joints and dust covers
Inspect body/chassis nuts and bolts
Top-off all fluids
Inspect drive shaft boots
Check exterior lights
Oil additive
Fuel additive
Inspect brake linings
Electrical check
All for $320!
Kent Kester
Rotate tires
Check tire pressure
Replace air filter
Top-off all fluids
Oil additive
Fuel additive
Electrical check
All for $320!
Kent Kester
[QUOTE=kkester]Here's what the dealer wanted for a 15,000 mile service:
Lubricate chassis and suspension (not needed on the truck as here is no grease points)
Rotate tires
Check tire pressure
Replace air filter
Top-off all fluids
Oil additive ( snake oil and a total rip)
Fuel additive (another rip)
Electrical check
All for $320! ( about 250.00 over priced
Rotate tires
Check tire pressure
Replace air filter
Top-off all fluids
Electrical check
