headlights
Old Apr 20, 2006 | 11:17 PM
79f-250custom's Avatar
79f-250custom
headlights
hey guys.
i have a 95 F-350 PSD. i need to remove my front right headlight if your looking at the front of the truck.
so how do these suckers come out?
thanks
Mitch
Old Apr 21, 2006 | 08:45 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Two Screws on the top of the light trim, Two nut on the inside of the headlight assembly, you have to reach way down inside and feel for them, 10 MM i think. Trim then pulls off. Each light adjustment screw has a slide down clip holding it in the metal bracket, pry up each clip, pull headlight forward, & unplug. A couple of months back someone posted an exploded view of the headlight assembly, try doing a search and it will show you the two nuts. I can change headlights without removing the batteries, but some poeple remove them to give themselves more room. Good Luck.
