Sponsored by: Real Truck
Missing relay question
Old Apr 20, 2006 | 10:31 PM
vancouverpower's Avatar
vancouverpower
Under the hood of my f250 I noticed a empty spot for two relays. It's a separate box between the master cylinder and the main power distribution box. Wires from this smaller box tap into the larger power distribution box
Anybody know what these relays are/were for?
Old Apr 20, 2006 | 11:28 PM
wlihntr's Avatar
wlihntr
for the 7 pin trailer tow plug. the front one is the trailer tow back-up lamp relay and the rear one is the trailer tow battery charge relay
Old Apr 20, 2006 | 11:40 PM
vancouverpower
Thanks for the info. I just hooked up a trailer for the first time and I'm trying to get the brakes to work.
The trailer doesn't have back up lights or a battery so I guess I won't need these two relays-right?
Old Apr 21, 2006 | 11:02 AM
wlihntr's Avatar
wlihntr
well there are also two fuses that have to be added in the under hood fuse box for everything to work. location #28, 30 amp maxi is the electric brake controller power fuse (you will need that) and location #16, 30 amp maxi is the battery charge fuse.
