Some Basic Questions.
Old Apr 20, 2006 | 10:16 PM
p521us's Avatar
p521us
Talking Some Basic Questions.
Ok so I have a couple of questions for you guys.
1. When the truck is started it idles very high for about 30sec then goes to a normal RPM. If I put it in gear when it is idling high it jerks very hard. What causes this and how can I fix it?
2. The overdrive light on the shifter column does not turn on when the over drive is off. How do I replace that?
3. If I took the cat and resonator off the exhaust and put a high-flow cat and a cheap glasspack on there should I be getting better gas mileage?
Thanks in advance. I’m kind of new with this so bear with me
Old Apr 20, 2006 | 10:52 PM
EPNCSU2006's Avatar
EPNCSU2006
1 is normal, my truck does that too. Blip the throttle, and it should come down. I can't help with number two, but for three, yeah, you should get a little better fuel economy.
