Old Apr 20, 2006 | 10:09 PM
Piters20's Avatar
Piters20
What should the gas milage be on a 390 engine on a 1972 ford pickup regular cab, long bed, C-6, 3.00 rear end, cfm 600 carb?
Old Apr 20, 2006 | 10:20 PM
Bdox's Avatar
Bdox
I had one years ago and it got 10-11 mpg.
Old Apr 20, 2006 | 10:29 PM
rusty70f100's Avatar
rusty70f100
It all depends on the state of the engine and the tuning. Old worn out engine = bad gas mileage. Incorrect tuning = bad gas mileage. It goes the other way too. Engine with good, consistant compression in all cylinders = good mileage. Correct timing and fuel mixture = good mileage.
Could be anywhere from 5 to 15mpg.
Old Apr 20, 2006 | 11:24 PM
jor's Avatar
jor
Bear in mind that rusty's "good mileage" is a relative concept. You really must add "for an FE!" I love my FEs but that love is getting more painful as we top $3 per gallon. Anyhow, I get about 8 mpg from my 390 that I drive hard and over 12 on my 360 that I poke along in.
jor
Old Apr 21, 2006 | 11:01 PM
FalconStng's Avatar
FalconStng
I'm getting around 10 mpg but I've got 4.1 gears and a heavy foot....Rusty mentioned good tuning....you also need good driving habits to get good mileage on an FE.
Tracy
Old Apr 22, 2006 | 12:15 PM
rusty70f100
Gas mileage is indeed a relative concept. I got 15mpg with my 390, 17 on one particular trip. What's interesting is dad's new 2006 F150 with the 5.4L averages 15.5mpg, and my engine is making a lot more power.
Old Apr 22, 2006 | 12:27 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
And my 390 that I built, 11:1 compression, big cam, etc, I got 15 on the highway doing 60-65MPH on a long 400+ mile trip. And it wasn't running lean, I checked
HOWEVER - that's in a 5500 lbs Highboy.
The V10 in my Superduty get's at least 15 on the highway, puts out more torque and the whole thing weighs at least 6500lbs.
Big truck, big gas bill. PERIOD.
Old Apr 22, 2006 | 05:59 PM
jd_sylvia's Avatar
jd_sylvia
I used to own a 68 F250 with a 390 C6 don't remember what the rearend had for gears, it would get about 13 to 14 mpg and that was even when I towed my fith wheel.
I now own a 65 with a 352 four speed granny tranny with 3.00 rear gears. Before the tunning and the gear change it used to get tops 9 mpg. Now if I keep it at 65 and watch the vacuum gauge I can get as high as 17 (rare) I have been averaging 15.5 mpg at 70 mph. I tow a small 14' boat to the lake and it doesn't change the mpg.
I will have to agree that it is in a good tune and a soft foot. Heavy foot cost you $$$.
jd
Old Nov 4, 2006 | 05:44 PM
Piters20's Avatar
Piters20
Thanks guys for your information. I've been busy. So hopefully in the future I can get at least 15 mpg. And as far as the motor I don't know how it exactly is, but it seems to be a good motor. That's just how I bought the pickup and was told there was nothing wrong with the motor. So my point is, Idon't know what kind of cam and compression it has. Or is there a way to find all that out?
Old Nov 4, 2006 | 05:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
jd
When new, my '65 F100...352 o/d used to get around 20-25 miles to the gallon on the road. After I changed it over to a 390, adding a 4 barrel and GT cam...the mileage dropped to around 18-20.
In town mileage has always been around 10-12.
390 blower
Apr 4, 2008 04:59 PM
ford390gashog
Aug 25, 2004 07:21 PM
ford390gashog
Jun 8, 2004 09:48 PM
ford390gashog
49
Apr 8, 2004 08:07 AM
390hiboy
Jul 26, 2001 10:32 PM
