Sponsored by: Auxito
Brights only half working...
Old Apr 20, 2006 | 08:52 PM
Patatoe1's Avatar
Patatoe1
I noticed today that my brights only turn on when I pull the light lever back towards me. When I push it forward to leave the brights on they don't come on at all.
Does anyone know what causes this or how to fix it?
Old Apr 21, 2006 | 02:07 PM
northernowl's Avatar
northernowl
It could be that the multifunction switch that controls the light is going bad.
Old Apr 21, 2006 | 03:33 PM
ddrumman2004's Avatar
ddrumman2004
That's my guess also. It's best to replace it now before it gets bad enough and your headlights go off like mine did before I replaced it. Kind of scary at night when it does that!
Old Apr 21, 2006 | 05:35 PM
Patatoe1's Avatar
Patatoe1
What is the multifunction switch, and how to do change it? If that turns out to be the problem.
Old Apr 22, 2006 | 10:52 AM
northernowl
The mulitfunction switch is the turn signal lever. It controls the headlights, turn signals, and wipers. To replace it you have to remove the ignition cylinder, and steering collum shrould.
Old Apr 22, 2006 | 11:22 AM
ddrumman2004
It can be changed without removing the ignition switch....I did it. More work but it can be done.
Old May 15, 2006 | 09:11 PM
Patatoe1's Avatar
Patatoe1
I noticed today that the brights do turn on when I push the lever forward IF the headlights are already on.
If the headlights are off the brights only work by pulling the lever back.
Does anyone have any ideas what this could be?
Old May 15, 2006 | 09:14 PM
RangerPilot's Avatar
RangerPilot
That's normal in our Rangers at least. The headlights have to be on to lock on the brights. The brief turn them on and off by pulling it towards you is the "flash to pass" function.
RP
Zach
Old May 15, 2006 | 09:16 PM
northernowl
It allows you to flash your high beams without having your headlights on and allows you to have the low beams and flash the high beams when you headlights are on.
Old May 15, 2006 | 09:22 PM
Patatoe1's Avatar
Patatoe1
Well I guess it must be normal then. Thanks for the quick replies guys.
Turbo Dog
2009 - 2014 F150
Sep 28, 2013 05:49 PM
Toplait
Sep 11, 2013 11:15 PM
dclark46
Mar 23, 2013 04:19 PM
dg416
1983 - 2012 Ranger & B-Series
Jan 19, 2012 01:17 PM
aquaman
Oct 28, 2009 02:33 AM
