Sponsored by: Real Truck
how much lift ?
Old Apr 20, 2006 | 08:04 PM
brikr's Avatar
brikr
how much lift ?
I have a 99 f 350 4x4 psd with u code (4800#)front springs that are very saggy. If i were to put x code (6000#) springs under do you gents think i could achieve at least a 2"-2.5" lift to go along with the extra 1200# spring rate? Looking to raise at least 2" and support a plow. I think if i hang a plow on it i will kill these u code springs. Thanks for any feedback.....
Old Apr 20, 2006 | 08:41 PM
Texascadillac42's Avatar
Texascadillac42
Id throw the X codes on, they will be able to handle the plow weight no problem, if it isnt enough lift, Id get a spring pack lift from Donahoe Racing. The X codes should pick you back up around 1.5-2" if your original springs are really blown out. The DR spring back will give another 1.75". Id go with the Xcodes first for sure.
