Help
Old Apr 20, 2006 | 10:24 AM
jrcalisi's Avatar
jrcalisi
Help
I need advice. I just recieved a call from the dealer and they want me to either purchase a cylinder head for 3K or a new engine for 7K to fix a misfire on #5 error code. I had already replaced the coil and the check engine light went away for a little while but returned. They are telling me that the valve's are sticking...
Am I being took for a ride or is this common on these engine's (5.4)? Oh to make it worse my extended warranty just expired this month sometime they can't tell me when.
Please help.
Thanks,
Jon
Old Apr 20, 2006 | 11:17 AM
amm888's Avatar
amm888
get a second opinion - perhaps a friend knows a trustworthy mechanic in your area
Old Apr 20, 2006 | 11:35 AM
01silvergt's Avatar
01silvergt
one thing you have going for you is that your warranty expired this month and your only 20 days in the month. I would try to get them to fix it under warranty, if they (service center) says no, go to their boss and so on up to the dealership owner. You can also call Ford customer service and ask them. Raise hell about the warranty just expiring and the problem is still present. Might also want to check the Lemmon Laws in your state and see if they apply to your case.
Good luck!
Old Apr 20, 2006 | 12:52 PM
wavinwayne's Avatar
wavinwayne
They're not called stealerships for nothing. Take it to an independent shop & get a second opinion.
If it were mine, & there really was a "sticking" valve, I would do a water de-carbon treatment through the brake booster vacuum line. Total cost - under $1.
Old Apr 20, 2006 | 05:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Jon to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 20, 2006 | 05:50 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
month out warranty, ask them to call the rep and "PL7" IT. should cost you 20% of repair and you get a warranty.
<br>
Ed
