Help With Cruise Control
Old Apr 20, 2006 | 09:56 AM
Mike8623's Avatar
Mike8623
96 PSD manual transmission: I noticed awhile back my cruise control wasn't holding as it should. I would hold just where I put it and after 30 minutes or so it would suddenly let go.........well I just reset it and kept going. Yesterday it started letting go a minute or so after I set it........Now today it won't set at all......any ideas on how to fix the dang thing............going on a long trip pretty quick and don't want to pedal it all the way.
Old Apr 20, 2006 | 10:48 AM
DaBigTow's Avatar
DaBigTow
Things to check...
1) Brake Pressure Switch on master cylinder.
2) Brake On/Off Switch by pedal.
3) Contacts on steering column (remove bottom column cover & clean grooves w/ QTip).
4) VSS on rear end if speedo is wobbling or ABS light comes on.
The last thing that comes to mind is the PSOM, Programmable Speedometer/Odometer Module, which costs about $600 at the stealership. A wobbly speedo is also an indicator of the PSOM failing.
Old Apr 20, 2006 | 11:27 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Also look at the clutch switch.
Old Apr 20, 2006 | 08:34 PM
1997F-350's Avatar
1997F-350
check all your rear lights even the 3rd brake light. have someone push the brakes. this is a common problem with our trucks.
Mother_Love
1978 - 1996 Big Bronco
Jan 20, 2017 10:04 AM
mksnipe
Dec 15, 2015 08:22 AM
Franken-Truck
17
Dec 25, 2011 03:11 PM
Edtrak
Jun 30, 2008 06:07 AM
John311t
Jun 10, 2007 04:33 PM
