electric pump and return line???
Old Apr 20, 2006 | 01:40 AM
littleme13's Avatar
littleme13
i have a problem with my 460 running incrediably rich it is mostly stock with only headers that i am aware of and a aftermarket electric fuel pump. my question is shouldnt there be a return line somewhere after the pump to blead off extra pressure. i have two lines coming from the a y just after the pump then before the carb they y back into one. so im wondering if someone didnt know what one was for and hooked them both up to pressure. PLEASE HELP!!!!
thanks
tony
Old Apr 20, 2006 | 08:21 AM
Putt's Avatar
Putt
It depends on the pump Tony, some are designed to maintain 4-6 psi for a carb without a return line, others need a regulator and return or just a dead head regulator. Do you have two tanks?? If you can get the make, model of the pump it would help.
Old Apr 20, 2006 | 10:47 AM
littleme13's Avatar
littleme13
yes i have two tanks but i dont think the rear is hooked up but i will get the pump info if i can later today it does have a regulator in it but the gage is broke i think cause it says 3 psi even when the truck is off i just found this out today so maybe the regulator is broke?? hmm i ill have to check
thanks
tony
Old May 15, 2006 | 06:51 PM
littleme13's Avatar
littleme13
well i found out the regulator diafram was torn so i replaced it put in a new regulator and it now runs better. now i think the carb is in need of some severe rebuilding so that will be next weekends prodject i think. also found out there is a return line to the tank but it has been pinched off after the stock pressure regulator.
Old May 16, 2006 | 03:59 PM
LxMan1's Avatar
LxMan1
The stock return like set-up was to keep fuel moving in the lines all of the time to prevent vapor-lock. You don't have to use it.
