Problem with DayStar 2" Leveling kit!!
Old Apr 19, 2006 | 09:31 PM
ApriliaHauler's Avatar
ApriliaHauler
Question Problem with DayStar 2" Leveling kit!!
Installed a 2” leveling kit on my 4x4 SCREW. Drove it for a week before I was able to get it aligned. Now I have a whining sound that I think is coming from the tires. Do you think noise is caused from the tires wearing too long with out an alignment? I still have the stock tires that came with the truck. Moving to 33’s later. Also, does anyone know what they do to correct the positive camber angle produced from a leveling kit? Do they use some kind of spacers? It still looks like I still have about a half of degree of positive camber; I haven’t taken back to the dealer yet. Any comments or suggestions would be appreciated.
Old Apr 20, 2006 | 12:47 AM
paul812's Avatar
paul812
these kits allow the toe in to come in, if your sure its the tires making the noise, i would bet money its just the toe in. You see, as the wheels drop down, (or the frame/body goes upward) the ends of the rack & pinion shafts go downward which pulls the tires in at the front. All the posts i've seen here, practically everyone said only the toe in was affected. I had autospring 1 1/2 installed in Jan. and also when i took it in, they said only the toe in had to be set. (off by about 1/2") But mine is a 4 x 2. I would have them re-check it. Does it do this noise all the time or just while turning? Maybe a 4 x 4 expert can also help you out.....paul
Old Apr 20, 2006 | 08:49 AM
ApriliaHauler
It makes the noise all of the time. The noise kind of sounds like I have mud grips on, but a higher pitch. I think I'll have the tires rotated and balanced and go talk to a 4x4 shop. Thanks for your reply Paul.
Old Apr 21, 2006 | 07:43 AM
derek4343's Avatar
derek4343
can you tell that the tires wore funny by looking at them? i've got the same kit and got my aligned the next day.only thing i hear now is a knock or rattle since i installed it.
Old Apr 22, 2006 | 09:13 AM
ApriliaHauler
No, I really tell just by looking at them. Until I had it aligned, I had some weird noises and it was kind of bouncy in the front. I did get the tires rotated and balanced and it is not as loud now. I think that's because of the rotation. Harder to hear the noise when the tires are on the rear.
Chevra
May 4, 2017 12:38 PM
Micheal G
Jun 18, 2016 07:33 AM
Indslpwr04
2009 - 2014 F150
Mar 30, 2016 07:00 PM
Gregxlt
2015 - 2020 F150
Nov 12, 2015 08:46 AM
95f150
May 13, 2005 08:41 PM
