Tachometer???
Old Apr 19, 2006 | 08:02 PM
wethugin87's Avatar
wethugin87
Post Tachometer???
I bought an aftermarket tachometer for my 96 ranger. It has the worst directions ever, it looks like a 2 year old drew them. It has 4 wires for the tach they are red green yellow and black. The directions say to wire the yellow wire to the battery + and the black to the battery -. I did that and then it says to wire the green to the coil -. And then the Red to the ignition +. This doesn't make any sense to me I dont have any idea which wires are which and where they are located for the red and green wires. Is there somebody that can help me? Is there a better way to wire it up and can you send me some pics of it or a diagram of some sort?
Old Apr 19, 2006 | 08:41 PM
RangerPilot's Avatar
RangerPilot
I believe the red wire goes to a wire with power only when the ignition is on. The green goes to the coil negative wire, which in this case can be used by the wire sending the tach signal to the PCM (your PCM gets an RPM signal whether you have a tach or not), just tap into the wire. Don't run the black wire to the batt negative terminal, just ground it somewhere.
If you need any more help, just drop me a PM.
RP
Zach
Old Apr 19, 2006 | 08:57 PM
wethugin87's Avatar
wethugin87
were would the coil be located though?
Old Apr 19, 2006 | 09:22 PM
RangerPilot
Depends on the engine. On my 4.0L, it's on the passenger side valve cover. It's the thing with all the spark plug wires comin' out of it.
RP
Zach
Old Apr 20, 2006 | 09:54 AM
wethugin87's Avatar
wethugin87
How can I figure out which is the negative off of the coil? I have the 2.3 liter I need help i dont know what to do
Old Apr 20, 2006 | 02:52 PM
RangerPilot
I'm not sure on the 2.3L, my Haynes is unhelpful to say the least. I'm not sure which coil on the 2.3L you'd run it off of either. It shows T/W and T/O wires running off of the primary coil and T/LB and T/LG wires running off the secondary coil. I assume you could tap either coil, but I'm not sure on the wire. It shows no ground or negative wire off either.
RP
Zach
Old Apr 20, 2006 | 06:54 PM
Tiggie's Avatar
Tiggie
You can splice into the PCM, which should be mounted on the passenger side firewall/fenderwell. You will need to splice into pin number 48, which will be a brown or tan wire with a yellow stripe, to obtain your engine RPM signal. Not sure if that would go to the green or red wire, but I'm thinking green.
Old Apr 20, 2006 | 07:24 PM
wethugin87's Avatar
wethugin87
So if the green goes to the PCM then where is the ignition + located?
Old Apr 20, 2006 | 07:36 PM
Tiggie's Avatar
Tiggie
I wouldsay on one of the terminals on one of the coil packs, but I'm not sure. Believe it or not, it's easier to install a factory tach than an aftermarket one, and that's what I did.
Old Apr 20, 2006 | 07:47 PM
wethugin87's Avatar
wethugin87
Does anybody know where the ignition + is located? This is the only wire that I need to hook up and I"m completely stumped now....
Old Apr 20, 2006 | 08:43 PM
pike_hunter's Avatar
pike_hunter
If you look at the ignition switch harness under the dash, you should find a Green wire with a Purple stripe. If you measure this with a digital volt meter, it should show 12 volts when the ignition switch is on and 0 when the ignition switch is off. This is the ignition positive for most applications.
Old Apr 21, 2006 | 04:12 PM
Tiggie's Avatar
Tiggie
Just a guess here, but you could try running the red wire to a 12V source that only has juice when the ignition is on. The RPM signal is coming from pin 48 on the PCM and I'm about 95% sure that is where the green wire goes. Usually, aftermarket tachometers are wired up this way:
Red - 12 V when ignition is ON
Black - ground
White - 12 V w/ ignition ON or illumination on the head light swith
Green - To the Tach test connector or tach test on coil (or RPM signal from PCM)
Old Apr 24, 2006 | 11:39 AM
wethugin87's Avatar
wethugin87
Tiggie
well I wired it up that way to pin 48 and it is reading the rpm signal but its not reading the right rpm. the highest rpm it reads is 2000. thanks for your help.
Andrew
Old Apr 24, 2006 | 03:25 PM
Tiggie's Avatar
Tiggie
Do you have you tach set right? There are different settings for 8-, 6-, and 4-cylinders. I think you'll need it set to 4-cylinder. Should be a switch somewhere on the back. Try the other settings and see what happens.
Usually when people tap the wrong wire, they'll get either a constant rpm reading (regarless of rpm) or something between 400-1000rpm.
Old Apr 24, 2006 | 07:48 PM
wethugin87's Avatar
wethugin87
Well its set to 4 cylinder (I did try the other ones) I tapped into the PCM wire and into the ignition wire and grounded to the chassis and then put a wire to the battery what could I be doing wrong?
BGF100
Oct 15, 2016 09:58 AM
Unaffiliated
Mar 31, 2016 10:31 AM
thaugen
Large Truck
Jul 31, 2012 09:23 AM
Chuck14
Electrical Systems/Wiring
Feb 23, 2009 04:41 PM
boogity24
30
Jan 19, 2004 11:28 PM
