71 2wd brakes
Old Aug 28, 2002 | 03:33 PM
jashforth's Avatar
jashforth
71 2wd brakes
[updated:LAST EDITED ON 28-Aug-02 AT 04:48 PM (EST)]i have converted my drumes to disk brakes but now my tires sit like this / \ i took it to get an alinment and they said they could not fix that what should i do?
Old Aug 28, 2002 | 06:00 PM
jowilker's Avatar
jowilker
71 2wd brakes
What parts did you use? I-beam swap or spindle swap won't cause that.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Aug 28, 2002 | 06:18 PM
jashforth's Avatar
jashforth
71 2wd brakes
i used a 73 spindel with a 71 i beam
Old Aug 28, 2002 | 09:24 PM
red68ranger's Avatar
red68ranger
71 2wd brakes
Does "/\" mean your tires are closer at the top than at the bottom or closer at the front than the back?
Dan Blackwell
Old Aug 29, 2002 | 05:05 AM
jowilker's Avatar
jowilker
71 2wd brakes
There is so little play in the kingpin area, that you couldn't notice any difference in the telementry. The problem had to pre exist.
Have you changed the coil springs too?
John
jowilker email me
Old Aug 29, 2002 | 07:54 PM
jashforth's Avatar
jashforth
71 2wd brakes
thanks i am going to replace the tie rods and the springs.
Old Sep 1, 2002 | 05:53 PM
sullyda1's Avatar
sullyda1
71 2wd brakes
The advice on not being able to realign your camber is dead wrong. First of all, you may have just noticed the camber angle. You should have some top tilt-in (camber) angle at the top on front tires, but none at the rear. Twin I beams can be reset .You need to have a qualifed front end shop look at your alignment. Most small shops as well as almost all large franchise tire shops(Firestone, Sears, etc.)are not equipped to set the camber on twin I beams. Shops that do trucks are your best bet. Try the yellow pages. To correct your camber a shop must bend the I beams.
Old Sep 1, 2002 | 06:06 PM
sullyda1's Avatar
sullyda1
71 2wd brakes
An after thought. I noticed you had not responded to Red68Ranger. Are you talking about toe-in.(toe-in is the amount the front of the tire is angled closer than the rear of the same tire) Whenever you change to late spindles, your toe-in will be drastically off. In fact, I don't think you could even drive without making a rough adjustment. Ideally 1/16" to 3/16" closer at the front
Old Sep 1, 2002 | 06:30 PM
jds1971's Avatar
jds1971
71 2wd brakes
