Due to Autometer temps of 235# I decided to install tranny cooler. After install of tru-cool tranny cooler I did a 30 mi test run on fwy and country roads. Had 210# reading, so was still concerned about running too hot. When I got home I felt the tru-cool and it felt cool to touch. Concerned that I had no flow, I pulled off return line (lower hard line with cheap clamp on it) and held the soft rubber end that came from the true-cool. Had wife start engine and was immediately drenched in tranny fluid coming out of the hard return line. (not the rubber one from coolers). I was surprised to see fluid coming from that direction and not the other. Also it was just warm, not hot...even though tranny guage still said it was 180#. Two questions: (1) Why was the fluid just warm to the touch if guage said it is 180#? and (2) Why was the fluid coming from the tranny instead of the cooler? I'm pretty sure I had the correct line (from the rear of tranny).
Are these temps towing? Typically, the trans temps are 60-80 degrees above ambient temps when unloaded. Those temps are high if you are not towing, especially with the temps in the Wisconsin. Wonder if you could have a bad gauge? Is the sending unit in the test port of the trans?
The trucool should be inline after the stock cooler and before the trans return. If you unhook the hose that connects to the return hardline that goes to back passenger side of the trans, you should have flow out of the hose. In the pic below, the hose with the clamp is the return and fluid should come out there. Is that where you tapped in?
I would pull your temp sensor and put in hot water while checking it with another temperature gauge you trust..Sounds like your gauge is reading to high if the oil feels just warm.. My trans temps run bout 180 pulling a load.. with the tru cool..
There is a bypass that allows fluid to bypass the cooler if the cooler is plugged. It is the black steel tube that runs between the two cooler fittings on the side of the transmission. It sounds like yours is stuck open, which will bypass the cooler. That will also allow fluid to come out of the rear fitting on the trans.
i was also seeing very high temps before and after the tru-cool. i checked my guage and found i had a bad ground and once that was fixed my guage doesnt read over 125. where is elroy?
Elroy is 11 miles southwest of Mauston. Mauston is on 90/94 between LaCrosse and Madison. I will check the ground. The other guages are working fine and lights at night as well.
The temps are without towing. The guage and sending unit are new and just installed. It is the model 4739. The sending unit is in the port driver's side just above the pan and in front of the linkage
I think casey is right, sounds like the bypass is stuck open.
checked the sending unit with hot water this morning ( about 150#) and it checked out OK. Thought it wasn't working so I took it out of the hot water and put it against the tranny pan and it grounded and showed a reading of 150#.
I looked for the black steel tube running between the two cooler fittings and could not find it. do you have a picture? I checked the sending unit this morning using hot water and it seemed to be fine.
There was a thread about this on the other site, and it sounds like the bypass is designed to let the oil get that hot. Since I doubt the link will stay up here long if I just post it, send me a pm and I can give you the link.
