Electric Fan Conversion
Another, less expensive, option is a fan from a Mark-8 with a relay fan control/trigger. I know a couple of people using the Mark-8 fan with a Painless wiring kit and they seem to work well for those guys.
298
http://store.summitracing.com/partdetail.asp?autofilter=1&part=FLX%2D298&N=42949 24500+4294838842+4294839058+400226+4294783223+115& autoview=sku
295
http://store.summitracing.com/partde...5&autoview=sku
Both are a better deal than this kit
298
295
Did you see a difference in gas mileage when the electric fan was installed?
I couldn't really say I got better mileage... as my engine is quite tired (390k miles). I get 10ish driving locally, and 13-14-15ish on the highway depending on a variety of things, mostly how late I am
It's also a crewcab, and weighs in at 6997 lbs according to the local brickyard.One for the EEC (factory) and another for the EEC (factory) that's in the crossover port on the intake to tell the EEC when the thermostat opens.
I could probably adapt to one of the existing senders by changing some resistors around and such but I've already drilled and tapped holes for the additional sending units so... probably not LOL.
Same concept as a switching power supply, like in your PC.
Once I'm happy with the final design, I'll mount it in a box and "pot" it so it's uneffected by weather, temperature, hammers and hungry wire eating rats.
This started off as an idea, which morphed into something to test on my workbench, and it will probably sit there until I install the new radiator, the new non-caddy electric fan, and of course, the 500cid stroker.
I'm slow.
I'm just being fancy with the PWM thing because I wanted to play with pulse width stuff. I have another project that requires a more precise PWM circuit so I merely wanted to find something less criitical to "play" on.
